Peavy XM4 Input Jack Replacement
  1. Peavy XM4 Input Jack Replacement, Remove Front panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are two screws at the top and two at the bottom
  2. Peavy XM4 Input Jack Replacement, Remove dial fixings: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Peavy XM4 Input Jack Replacement, Remove dial fixings: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • All of the dials have a rubber cover and a nut, these need to be removed from all of the dials. The Jack inputs also have a nut holding them in place, remove these also.
  3. Peavy XM4 Input Jack Replacement, Remove input jack: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Peavy XM4 Input Jack Replacement, Remove input jack: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the input jack by desoldering the pins on the other side of the board, you may want to use a solder remover tool to make it easier.
  4. Peavy XM4 Input Jack Replacement, Solder new jack: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Solder the new jack in place, the jack i used had an extra pin but was not needed. i ended up bending it out of the way and it all still works.
  5. Peavy XM4 Input Jack Replacement, Re-assemble: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the jack or jacks have been replaced simply re-assemble by working backwards, remember that the dials each have a screw and a topper. when putting the toppers back on make sure the dials are turned to the minimum value and line them up to avoid confusion when being used.
Josh Walford
crwdns2935283:001/12/18crwdne2935283:0
199 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 227
