Paw Patrol Toy Garbage Truck - Fixing Broken Solder Joint
  1. Paw Patrol Toy Garbage Truck - Fixing Broken Solder Joint, Fixing Broken Solder Joint and Cable Routing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Paw Patrol Toy Garbage Truck - Fixing Broken Solder Joint, Fixing Broken Solder Joint and Cable Routing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This is the truck we are talking about. The Spin Master garbage truck of the dog Rocky from the TV series Paw Patrol
  2. Paw Patrol Toy Garbage Truck - Fixing Broken Solder Joint: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Paw Patrol Toy Garbage Truck - Fixing Broken Solder Joint: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • We need to remove seven PH#1 screws. I recommend a along screw driver without bit holder to do this.
    • Two of the screws are hidden underneath the rear tires. You have to slide your screw driver behind the tire down to the screw hole. The tires are not removable.
  3. Paw Patrol Toy Garbage Truck - Fixing Broken Solder Joint: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Paw Patrol Toy Garbage Truck - Fixing Broken Solder Joint: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You can now remove the bottom half from the top.
    • Inside the truck you will find two LEDs for the lights.
    • A speaker for the sound.
    • A small PCB.
    • Also there are the connections from your battery holder
    • You can remove the orange fork to get a better view of the contacts.
    • I had to reflow them with the soldering iron and bent them a little bit down to avoid further touching of the fork shaft
  4. Paw Patrol Toy Garbage Truck - Fixing Broken Solder Joint: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finally a tipp for the reassembly of the truck.
    • If you had all screws falling out, you can slide the two blue trash cans down, to easily place the two hidden screws.
    • Gratulations, you are done!
Go the steps revers to reassemble the toy.
TheLOD2010
crwdns2935283:010/30/15crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 339
