Patching a 125 2 stroke fuel tank
  1. Patching a 125 2 stroke fuel tank, Patching a 125 2 stroke fuel tank: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First, you will need to sand down the rough edges around the hole in fuel tank.
    • Make sure the hole in the fuel tank and its surrounding is as smooth as possible.
  2. Patching a 125 2 stroke fuel tank: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the hole is smooth. Apply fuel patch with q-tip over hole and the surrounding edges.
  3. Patching a 125 2 stroke fuel tank: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure that the ointment is spread thickly over the hole.
  4. Patching a 125 2 stroke fuel tank: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Avoid having air pockets in the ointment. Air pockets may make the patch less effective or not seal at all.
    • Once the ointment is spread over smoothly, you will need to rub the edges out so there is no edge that can be caught on something.
  5. Patching a 125 2 stroke fuel tank: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let the patch dry over.
    • Try not to touch patch until completely dry. This may take a couple hours.
  6. Patching a 125 2 stroke fuel tank: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next, you will need to check the patch after completely dry. Make sure there is no bubbles or edges where there could be another potential leak.
    • Once patch is dry put fuel in the tank.
    • When tank is full check to see if there are any leaks in the patch. Leaks consist of fuel dripping or even air leak from patch.
    • If there are leaks scrape off patch and repeat process.
  7. Patching a 125 2 stroke fuel tank: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • When there are no leaks start riding. Your tank is now patched. Check up on patch after ride to make sure it is still sealed.
Andrew
crwdns2935283:002/17/15crwdne2935283:0
1,387 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 1,468
