Parrot Skycontroller 2 Power Port Replacement
  1. Parrot Skycontroller 2 Power Port  Replacement, Power Port: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Parrot Skycontroller 2 Power Port  Replacement, Power Port: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Parrot Skycontroller 2 Power Port  Replacement, Power Port: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the controller upside down.
  2. Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 9mm screw using a #4 flathead screwdriver.
  3. Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opening tool into the top of the battery cover and pry upwards to lift the cover.
    • Remove the cover by pulling up and out.
  4. Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling apart.
  5. Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery from it's brackets by pulling up gently on the ends of the battery.
    • Some force may be required to separate the battery from it's brackets.
  6. Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
    • There is a hidden screw located behind the sticker in the battery compartment.
    • Pull back the sticker with your finger nail and remove the one black 11mm screw using the Torx TR6 screwdriver.
  7. Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the seven silver 4mm screws from around the edge of the top panel using the Torx TR6 Screwdriver.
    • The opposite side to the third picture has a screw located on each side of the USB port.
  8. Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery compartment plate by pulling up and out.
  9. Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top plate by pushing on the corners with your hand.
    • Be careful to not pull too hard on the cable.
  10. Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the face plate by pulling up and out.
  11. Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Parrot Skycontroller 2 Power Port  Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the controller is flat, then proceed to desolder the power port.
    • Desolder the four connection points surrounding the charging port.
    • Remove the power port from the controller.
    • For help with soldering best practices, check out our How to Solder and Desolder Connections guide.
    • Excessive heat can damage the power port, so do not apply the soldering iron to the component for too long.
Jonathan Epperly
crwdns2935283:001/26/20crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S6-G1, Watkins Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S6-G1, Watkins Spring 2020crwdne2935289:0
ERAU-WATKINS-S20S6G1
crwdns2942667:0crwdne2942667:0 614
