Before replacing most other part on this device, the battery must be properly disconnected in order to continue on. This guide will teach you how to remove and replace the battery.
            Begin by removing the velcro strap around the battery.
            While holding onto the nose, gently pull the battery away from the nose.
            Once the battery is separated from the nose, push down on the connector and pull the battery away from the connector.
