Parrot AR.Drone 2.0 Propeller and Gear Replacement
crwdns2936621:0crwdne2936621:0
  1. Parrot AR.Drone 2.0 Propeller and Gear Replacement, Propeller and Gear: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Parrot AR.Drone 2.0 Propeller and Gear Replacement, Propeller and Gear: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the foam body.
  2. Parrot AR.Drone 2.0 Propeller and Gear Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Parrot AR.Drone 2.0 Propeller and Gear Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
    how do i put the clips back in?
    kuki vier - crwdns2934203:0crwdne2934203:0
    Are you referring to the clips in step three? If so, i highly recommend a hard, flat edged tool like a plastic spudger or flat head screw driver. Push is against the opposite side of the C clip that is opened with roughly the same force you applied to get it off. You have to be really careful that you push it directly horizontal or else you might damage the shaft or risk loosing the clip if it pops off.
    David Hoyt -
  3. Parrot AR.Drone 2.0 Propeller and Gear Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the small retaining clip using a plastic opening tool.
    • Be careful as these clips can fly off and can be difficult to find.
  4. Parrot AR.Drone 2.0 Propeller and Gear Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Parrot AR.Drone 2.0 Propeller and Gear Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Parrot AR.Drone 2.0 Propeller and Gear Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The propeller, gear, and rod can be removed by simply lifting them off the motor.
David Hoyt
crwdns2935283:004/09/10crwdne2935283:0
4,053 crwdns2915208:0crwdne2915208:0
crwdns2935297:041crwdne2935297:0
Cal Poly, Team 25-89, Amido Spring 2010 crwdns2935289:0Cal Poly, Team 25-89, Amido Spring 2010crwdne2935289:0
CPSU-AMIDO-S10S25G89
crwdns2935297:061crwdne2935297:0
any idea how to change the little gear?
Dar BS - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 8,597
