Use this guide to replace, propellers, shafts, and gears on a Parrot AR.Drone 2.0.
AR.Drone 2.0 spare parts and mounting tools are available from several Parrot retailers.
crwdns2936621:0crwdne2936621:0
Remove the foam body.
Disconnect the battery by pulling the two red wires apart.
Remove the battery by releasing the battery retaining straps.
Remove the small retaining clip using a plastic opening tool.
The propeller, gear, and rod can be removed by simply lifting them off the motor.
crwdns2917034:0crwdne2917034:0
any idea how to change the little gear?
