Parrot AR.Drone 2.0 Motor Replacement
crwdns2936621:0crwdne2936621:0
  1. Parrot AR.Drone 2.0 Motor Replacement, Propeller and Gear: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Parrot AR.Drone 2.0 Motor Replacement, Propeller and Gear: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the foam body.
  2. Parrot AR.Drone 2.0 Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Parrot AR.Drone 2.0 Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
  3. Parrot AR.Drone 2.0 Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the small retaining clip using a plastic opening tool.
    • Be careful as these clips can fly off and can be difficult to find.
  4. Parrot AR.Drone 2.0 Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Parrot AR.Drone 2.0 Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Parrot AR.Drone 2.0 Motor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The propeller, gear, and rod can be removed by simply lifting them off the motor.
  5. Parrot AR.Drone 2.0 Motor Replacement, Motor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Parrot AR.Drone 2.0 Motor Replacement, Motor: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the connector at the bottom of the motor assembly.
  6. Parrot AR.Drone 2.0 Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 5mm screws on the top of the motor assembly with a PH00 bit.
  7. Parrot AR.Drone 2.0 Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 5mm screws on the bottom again using a PH00 bit.
    • The three screws from the top are different from the three screws on the bottom.
  8. Parrot AR.Drone 2.0 Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Parrot AR.Drone 2.0 Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully wiggle out the motor assembly out of the arm.
crwdns2935229:05crwdne2935229:0
David Hoyt
crwdns2935283:004/09/10crwdne2935283:0
4,053 crwdns2915208:0crwdne2915208:0
crwdns2935297:041crwdne2935297:0
Cal Poly, Team 25-89, Amido Spring 2010 crwdns2935289:0Cal Poly, Team 25-89, Amido Spring 2010crwdne2935289:0
CPSU-AMIDO-S10S25G89
crwdns2935297:061crwdne2935297:0
are the motors different on each side?
dbksoft - crwdns2934203:0crwdne2934203:0
I need to know this also. replaced cross.member but did not put motors in original spots now my drone goes crazy and erratic
Steven Maloney -
crwdns2942667:0crwdne2942667:0 6,074
