Parrot AR.Drone 2.0 Central Cross Replacement
crwdns2936621:0crwdne2936621:0
  1. Parrot AR.Drone 2.0 Central Cross Replacement, Mainboard and Navigation Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the foam body.
  2. Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
  3. Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the drone upside down.
    • The cover is held on by plastic tape. Peel off the tape and use a spudger to remove the back cover.
  4. Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, separate the connector for the downward camera.
    • Remove the camera from the body by pulling it off the foam body.
  5. Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to release the black retaining clip. Then disconnect the connector to the sensors.
    • Use tweezers to carefully remove the ribbon from the connector.
    How can I get that connector, the one it’s disconnected?
    gui txr - crwdns2934203:0crwdne2934203:0
  6. Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 8mm torx screws with a T6 bit.
    • Remove the four 8mm philips head screws with a PH00 bit.
  7. Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the secondary board from the mainboard.
  8. Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the drone right side up
    • Remove the USB connector from the battery retaining straps.
  9. Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the rubber clip holding the USB and battery power cable to the body.
  10. Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Avoid using sharp tools near the battery.
    • Push the USB and power cable through the battery panel.
  11. Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the drone upside down again.
    • Use a spudger to release the connector and carefully remove the ribbon.
  12. Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the mainboard up so that you can access the back.
    • Disconnect the first connector with the white wires using a nylon spudger.
    • Disconnect the second connector with the red and black wires using a spudger.
  13. Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The mainboard is now fully detached and can be removed.
  14. Parrot AR.Drone 2.0 Central Cross Replacement, Central Cross: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a nylon spudger, peel off the four pieces of plastic securing the frame to the body.
  15. Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully maneuver the four arms of the drone’s central cross until it detaches from the body by pulling apart the foam surrounding the arms.
    between arm 1 and arm 2 there is a little triangle on the central cross, that should point to the front.
    deebee122 - crwdns2934203:0crwdne2934203:0
  16. Parrot AR.Drone 2.0 Central Cross Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The central cross can now be removed and replaced.
David Hoyt
crwdns2935283:004/09/10crwdne2935283:0
4,053 crwdns2915208:0crwdne2915208:0
crwdns2935297:041crwdne2935297:0
If the crossbones are off just a bit would that effect the flight?
John Wurst - crwdns2934203:0crwdne2934203:0
So once I have removed the central cross, how do I put it all back together again?? I feel as though this is letting your guide down!!!!
Jacob Kenworthy - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 6,280
