Panasonic Toughbook CF-29 Wireless Card Replacement
  1. Panasonic Toughbook CF-29 Wireless Card Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Wireless Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Toughbook CF-29 Wireless Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Wireless Card Replacement, Back Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  4. Panasonic Toughbook CF-29 Wireless Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  5. Panasonic Toughbook CF-29 Wireless Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  6. Panasonic Toughbook CF-29 Wireless Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Toughbook CF-29 Wireless Card Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  7. Panasonic Toughbook CF-29 Wireless Card Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  8. Panasonic Toughbook CF-29 Wireless Card Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now the back cover should be off and you can access the inside of the casing.
  9. Panasonic Toughbook CF-29 Wireless Card Replacement, Wireless Card: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black and white wires attached to the wireless card by simply pulling up.
  10. Panasonic Toughbook CF-29 Wireless Card Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel back the black cover to expose the clips holding in the wireless card.
  11. Panasonic Toughbook CF-29 Wireless Card Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a pair of plastic opening tools, push the two metal tabs away from the card.
  12. Panasonic Toughbook CF-29 Wireless Card Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Toughbook CF-29 Wireless Card Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The wireless card should now easily disengage from the motherboard.
    • Pull the card horizontally away from you to remove it from its housing.
Devon Augustus
crwdns2935283:004/12/10crwdne2935283:0
130 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 27-93, Amido Spring 2010 crwdns2935289:0Cal Poly, Team 27-93, Amido Spring 2010crwdne2935289:0
CPSU-AMIDO-S10S27G93
crwdns2935297:026crwdne2935297:0
what about the heatsinks of the processors? You don't fix the contact surface to the cover?
michael - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 14,932
