Panasonic Toughbook CF-29 Touchscreen Replacement
  1. Panasonic Toughbook CF-29 Touchscreen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Touchscreen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Toughbook CF-29 Touchscreen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Touchscreen Replacement, Touchscreen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four hinge screws from the back of the computer.
  4. Panasonic Toughbook CF-29 Touchscreen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Toughbook CF-29 Touchscreen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the laptop and remove the four indicated screws with a Phillips size 0 screwdriver.
    • Pry off the plastic strip which was previously held in place by the screws.
  5. Panasonic Toughbook CF-29 Touchscreen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four hinge screws to allow the hinges to rotate up and move.
  6. Panasonic Toughbook CF-29 Touchscreen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 16 screws from the top of the closed laptop.
    • 12 Phillips size 1 screws
    • 2 Phillips size 0 screws
    • 2 Torx size 6 screws (T6)
  7. Panasonic Toughbook CF-29 Touchscreen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently break the adhesive seal between the front and rear display cases with a plastic opening tool.
    • You will need to reapply the silicon adhesive during reassembly to ensure watertight seal.
  8. Panasonic Toughbook CF-29 Touchscreen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the top halve of the casing up revealing the inside of the screen
  9. Panasonic Toughbook CF-29 Touchscreen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Toughbook CF-29 Touchscreen Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The top half of the case can be removed by sliding the tabs out from under the hinges.
    • This makes unplugging the screen wiring much easier
  10. Panasonic Toughbook CF-29 Touchscreen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There are 4 wires that need to be unplugged to remove the screen.
  11. Panasonic Toughbook CF-29 Touchscreen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • For the first wire, peel back the silver cover tape to reveal the connection.
  12. Panasonic Toughbook CF-29 Touchscreen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the wiring away from the connection to release it.
  13. Panasonic Toughbook CF-29 Touchscreen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3 strips of black tape as shown to reveal connections 2 and 3.
    • Pull the wiring for each away from the connections to remove.
  14. Panasonic Toughbook CF-29 Touchscreen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The 4th connection is already visible.
    • Depending on your model it might not be plugged into anything. If it is, remove it the same way the other 3 connections were removed.
  15. Panasonic Toughbook CF-29 Touchscreen Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Toughbook CF-29 Touchscreen Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, lift the screen as shown from the case and pull free.
crwdns2935229:05crwdne2935229:0
Dylan Bloom
crwdns2935283:004/12/10crwdne2935283:0
373 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 27-93, Amido Spring 2010 crwdns2935289:0Cal Poly, Team 27-93, Amido Spring 2010crwdne2935289:0
CPSU-AMIDO-S10S27G93
crwdns2935297:026crwdne2935297:0
This guide is good for replacing the LCD screen, but it is not complete for the touchscreen panel, which requires some more delicate and precise steps. I think the title of the guide needs to be changed.
Thanks
Alessandro Cervelli - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 17,467
