Panasonic Toughbook CF-29 Speaker Replacement
  1. Panasonic Toughbook CF-29 Speaker Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Toughbook CF-29 Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Speaker Replacement, Back Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  4. Panasonic Toughbook CF-29 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  5. Panasonic Toughbook CF-29 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  6. Panasonic Toughbook CF-29 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Toughbook CF-29 Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  7. Panasonic Toughbook CF-29 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  8. Panasonic Toughbook CF-29 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now the back cover should be off and you can access the inside of the casing.
  9. Panasonic Toughbook CF-29 Speaker Replacement, Speaker: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the back cover infront of you so you can access the inside of it.
    • Remove the 3 screws holding in the speaker.
  10. Panasonic Toughbook CF-29 Speaker Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry out the speaker using a flat screw driver or a blue pry tool. It is held in with an adhesive.
  11. Panasonic Toughbook CF-29 Speaker Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Your speaker is now removed
    • Put in your replacement by following the reverse steps.
Rohun Heesen
crwdns2935283:004/13/10crwdne2935283:0
426 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 27-93, Amido Spring 2010 crwdns2935289:0Cal Poly, Team 27-93, Amido Spring 2010crwdne2935289:0
CPSU-AMIDO-S10S27G93
crwdns2935297:026crwdne2935297:0
crwdns2942667:0crwdne2942667:0 5,494
