crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Panasonic Super Lite Flashlightcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Panasonic Super Lite Flashlight Teardown, Panasonic Super Lite Flashlight Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Twist the top assembly of the flashlight off by turning it counterclockwise above the rubber gasket.
  2. Panasonic Super Lite Flashlight Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the top assembly with the lens downward to avoid dropping the bulb during this step.
    • Unscrew the bulb base by twisting counter-clockwise, taking care not to drop the bulb. Remove the bulb.
  3. Panasonic Super Lite Flashlight Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber gasket from the top assembly.
  4. Panasonic Super Lite Flashlight Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Super Lite Flashlight Teardown: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Super Lite Flashlight Teardown: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the reflector by applying pressure to one of the two protruding plastic tabs using a small flathead screwdriver while pulling on the reflector.
    • The reflector should pop out; pull gently but firmly to avoid scattering the pieces. Remove the lens.
  5. Panasonic Super Lite Flashlight Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the batteries from the flashlight body.
  6. Panasonic Super Lite Flashlight Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the metal screwdriver as pictured: oriented vertically, underneath the yellow plastic piece in the switch assembly, between the metal contact of the switch and the gray plastic slider flange.
    • Pry upward to remove the yellow plastic piece; the metal contact piece may pop out with the plastic piece.
    • Once the metal and plastic are unseated from one side, pull out the metal contact and yellow plastic piece with pliers or fingers. Remove these pieces.
  7. Panasonic Super Lite Flashlight Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use pliers to pinch the gray flanges of the switch slider and apply pressure to push the switch out of the flashlight body.
Colin Mitchell
crwdns2935283:004/11/11crwdne2935283:0
269 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 25-26, Garner Spring 2011 crwdns2935289:0Cal Poly, Team 25-26, Garner Spring 2011crwdne2935289:0
CPSU-GARNER-S11S25G26
crwdns2942667:0crwdne2942667:0 3,117
