Panasonic SDR H-100 HDD Replacement
  1. Panasonic SDR H-100 HDD Replacement, Remove Bottom Screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic SDR H-100 HDD Replacement, Remove Bottom Screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 4-mm screws on the bottom of the camcorder.
    • The screws are two different colors: three blacks and one silver.
  2. Panasonic SDR H-100 HDD Replacement, Remove Side Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 6-mm screws on the hand-strap side of the camera.
  3. Panasonic SDR H-100 HDD Replacement, Remove DC Input Terminal Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the charging port (DC input terminal) cover and remove the 4-mm screw located next to the input terminal.
  4. Panasonic SDR H-100 HDD Replacement, Remove LCD Monitor Screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic SDR H-100 HDD Replacement, Remove LCD Monitor Screws: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip out the LCD screen to expose the inner screws. Remove the two black 4-mm screws.
    • One screw is located by the hinge of the LCD screen. The second is close to the upper-right corner of the camcorder body.
    • Using a firm hold on both sides of the camcorder, gently pull apart the casing under the hand strap.
    • Pressure should be evenly distributed across entire device.
    • Detach gently so the ribbon cable is not damaged!
  5. Panasonic SDR H-100 HDD Replacement, Detach Ribbon Cable from Body: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to grab the ribbon cable at the connection point and slowly lift it away from the connector.
    • This linkage point connects the HDD directly to the motherboard.
  6. Panasonic SDR H-100 HDD Replacement, HDD: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4 mm silver screws located on the HDD casing.
  7. Panasonic SDR H-100 HDD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the black plastic hard drive case away from the body of the camera. This will expose the hard drive (HDD).
  8. Panasonic SDR H-100 HDD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off the HDD gently from the casing with a plastic opening tool.
    • Make sure to run the tool underneath the HDD as you pry it off.
  9. Panasonic SDR H-100 HDD Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The HDD has been removed and ready to be replaced.
Caleb Osborne
crwdns2935283:004/08/15crwdne2935283:0
837 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 2-2, Matresse Spring 2015 crwdns2935289:0Eastern Washington University, Team 2-2, Matresse Spring 2015crwdne2935289:0
EWU-MATRESSE-S15S2G2
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 1,846
