If you need to replace the HDD of your Panasonic SDR H-100, follow this guide. The HDD is where the memory is stored for the camcorder. Without this the videos and pictures that are taken cannot be saved.
Remove the four 4-mm screws on the bottom of the camcorder.
Remove the three 6-mm screws on the hand-strap side of the camera.
Pull out the charging port (DC input terminal) cover and remove the 4-mm screw located next to the input terminal.
Flip out the LCD screen to expose the inner screws. Remove the two black 4-mm screws.
Using a firm hold on both sides of the camcorder, gently pull apart the casing under the hand strap.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to grab the ribbon cable at the connection point and slowly lift it away from the connector.
Remove the two 4 mm silver screws located on the HDD casing.
Gently pull the black plastic hard drive case away from the body of the camera. This will expose the hard drive (HDD).
Pry off the HDD gently from the casing with a plastic opening tool.
The HDD has been removed and ready to be replaced.
