The front panel of this device is fairly easy to remove, being held on by clasps, but you'll have to remove the top and side panels first. However, using this guide, with a Phillips #2 screwdriver and plastic opening tool, the replacement should only take around 15 min to accomplish.
Remove the five 9 mm #2 Phillips screws from the side panel nearest the power button.
Repeat the process for the opposite panel.
Remove the two 15 mm #2 Phillips screws from the back of the top panel.
Remove the middle 10mm #2 Phillips screw from the back of the top panel.
Swing the back half of the panel slightly away from the unit. Then, starting at the top back corner, slide plastic opening tool through the created gap from back to front. The panel should pop off. Repeat the process on the opposite panel.
Looking in through the side nearest the power button, use your fingers to pull the white ribbon connection toward you, away from the rear circuit board.
Remove the top panel. You will need to slightly bend the plastic tab outwards, to undo the clasp that is attached to the top.
Locate the white connector where the top black ribbon wire attaches to the green and black circuit board.
Pinch the tabs on the white connector and pull it partially out.
Hold the black ribbon wire directly and pull it the rest of the way out.
Pull the white ribbon cable from its base on the tan circuit board-located on the side of the system opposite the power button.
On the bottom sides of the front panel, pull the tabs outward to unclip the clasps.
Tilt the whole system up and unlock the bottom clasp of the front panel by pulling it toward you.
After placing the system back down, pull the front panel toward you to remove it.
