This repair guide will show you how to replace the tape player unit of your Panasonic SA-PM17 by tearing down the device to the point where you can take the unit out and put a new one in.
With a Phillips #0 screwdriver, remove the eight 9.5mm screws attached to the left and right panels of the device.
With a Phillips #0 screwdriver, remove the five 11.5mm screws attached to the backside panel of the device.
Detach the right and left panels from the device.
Lift the top panel and gently place alongside the device.
Allow the top panel to rest on the back without reattaching it.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
With the tweezers, detach the indicated tabs from the hooks by lifting upward.
Lift the top panel upward while firmly sliding it towards the back of the device.
Disconnect the black wire by gripping the wire at the base and pulling gently until released.
This step deals with the indicated area of the device.
Using the tweezers, detach the indicated tabs so that the cord may be released from the restraints.
Gently pull on the cord, near its base, until it comes free of the restraint.
Lift the indicated tabs out until the restraint looks like the final picture.
Gently pull on the cord until it is released from the attachment.
The top panel is now disconnected from the device.
Remove the four 12.1mm screws using a Phillips #0 screwdriver.
This step deals with the indicated area.
Using the tweezers, pull the indicated latch to the right to disconnect the tape player unit from the top of the device.
While holding the latch to the right, lift the unit up from the plastic.
The problem with my micro system pm17 is that the tape drive's head does not work. I noticed that it is a gear that has the function to trigger,The gearbox has probably moved out of its original position and is now not turning the read head.How do I return the gear to the original position so that it re-engages the bedhead?
Rogerio - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Add a comment
