This guide will show you how to replace the tape player cover of your Panasonic SA-PM17. The tape player cover protects your cassette tape in the device. Cassettes are not used very much anymore however they are fragile media and it's recommended that you use the tape player with a cover.
With a Phillips #0 screwdriver, remove the eight 9.5mm screws attached to the left and right panels of the device.
With a Phillips #0 screwdriver, remove the five 11.5mm screws attached to the backside panel of the device.
Detach the right and left panels from the device.
Lift the top panel and gently place alongside the device.
Allow the top panel to rest on the back without reattaching it.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
With the tweezers, detach the indicated tabs from the hooks by lifting upward.
Lift the top panel upward while firmly sliding it towards the back of the device.
Disconnect the black wire by gripping the wire at the base and pulling gently until released.
This step deals with the indicated area of the device.
Using the tweezers, detach the indicated tabs so that the cord may be released from the restraints.
Gently pull on the cord, near its base, until it comes free of the restraint.
Lift the indicated tabs out until the restraint looks like the final picture.
Gently pull on the cord until it is released from the attachment.
The top panel is now disconnected from the device.
Remove the four 12.1mm screws using a Phillips #0 screwdriver.
This step deals with the indicated area.
Using the tweezers, pull the indicated latch to the right to disconnect the tape player unit from the top of the device.
While holding the latch to the right, lift the unit up from the plastic.
Using your thumbs, push the casing forward.
Pull back on the peg while pulling forward on the tab until the peg comes out of its hole.
Lift the peg up and allow it to rest on top of the casing, as indicated.
Pull back on the peg while pulling forward on the tab.
Once the peg is loose of its hole, lift upward until it is clear of the tab.
Lift the cover up and out from the inside of the top section.
If at first the cover does not come free, jiggle it around until it does. Do not force it out.
