Panasonic SA-HT810V DVD Drive Replacement
  1. Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove the screw that is on the right side of the panel facing you.
    • Remove all screws with a phillips head screwdriver.
  2. Panasonic SA-HT810V DVD Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic SA-HT810V DVD Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the device so that the back faces you.
    • Using a phillips head screw driver, locate and remove the two screws highlighted by the red circles in image one.
  3. Panasonic SA-HT810V DVD Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before removing cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. Panasonic SA-HT810V DVD Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic SA-HT810V DVD Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic SA-HT810V DVD Drive Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up the two tabs on top
    • Pull the the three tabs on the side. One is on the left, and two are on the right side of the device when it is facing you.
    • Depress the four tabs on the bottom of the device with a flat head screwdriver.
  5. Panasonic SA-HT810V DVD Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull off the front panel of the device.
    • The front is attached to the device with cables so be careful when removing.
  6. Panasonic SA-HT810V DVD Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic SA-HT810V DVD Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws around the DVD drive with a phillips head screwdriver.
  7. Panasonic SA-HT810V DVD Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The DVD player is attached to the power supply.
    • Remove the wire attaching it by firmly pulling on the wire until it releases.
  8. Panasonic SA-HT810V DVD Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the DVD drive so that the bottom is facing you.
    • Pull on the blue ribbon cable until it releases.
    • To place the new DVD drive in just follow these steps in reverse.
Nathan Cheadle
crwdns2935283:004/15/10crwdne2935283:0
161 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 16-5, Maness Spring 2010 crwdns2935289:0Cal Poly, Team 16-5, Maness Spring 2010crwdne2935289:0
CPSU-MANESS-S10S16G5
crwdns2942667:0crwdne2942667:0 1,646
