Panasonic PV-GS9 LCD panel replacement
  1. Panasonic PV-GS9 LCD panel replacement, Microphone Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic PV-GS9 LCD panel replacement, Microphone Replacement: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic PV-GS9 LCD panel replacement, Microphone Replacement: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the blue plastic tool opener, then remove both the round record/playback and record/power control knobs by prying it open from the camcorder.
  2. Panasonic PV-GS9 LCD panel replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic PV-GS9 LCD panel replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the tape compartment.
    • Flip over the camcorder and find the two 4.5mm screws, which are approximately 2 inches apart.
    • Using a #00 Phillips screwdriver, remove the screws
  3. Panasonic PV-GS9 LCD panel replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic PV-GS9 LCD panel replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic PV-GS9 LCD panel replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic prying tool, remove the gray trim piece by opening and gently prying it off from top of the camcorder.
    • Be gentle when removing the trim piece. The plastic parts are fragile and can break easily.
  4. Panasonic PV-GS9 LCD panel replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the camcorder so that the camera lens is facing you.
    • Remove the four black 4.5mm screws, sitting behind the battery.
    • Remove the 5th screw to the right of the battery dock.
    • Remove the battery by gently pulling away from the camcorder.
    • Organize the screws in a sorting compartment to avoid losing them.
  5. Panasonic PV-GS9 LCD panel replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic PV-GS9 LCD panel replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the camcorder so that the tape compartment is facing you.
    • Remove the single 4.5mm black screw above the hook for the hand strap.
    • Undoing the strap on one end may help.
    • Rotate the camcorder so that the lens is facing you.
    • Remove the single 4.5mm black screw from the front panel.
  6. Panasonic PV-GS9 LCD panel replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic PV-GS9 LCD panel replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the camcorder so that the bottom is facing towards you.
    • Remove the single remaining 4.5mm black screw from the bottom.
    • Remove the four silver 4.5mm screws from the body.
  7. Panasonic PV-GS9 LCD panel replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the LCD screen on the side of the camcorder.
    • Using a #00 screwdriver, remove the two 4.5mm silver screws located on either side of the hinge of the LCD screen.
  8. Panasonic PV-GS9 LCD panel replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic PV-GS9 LCD panel replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully detatch the front cover from the body of the camcorder.
    • This should come apart with relative ease; however, a plastic pryer tool may help remove the panel if it is struggling to come apart.
    • Be careful as there is a ribbon cable attached to the front panel and the camcorder body, DO NOT tug at it when you remove this panel.
  9. Panasonic PV-GS9 LCD panel replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic PV-GS9 LCD panel replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your fingers, carefully pull the ribbon cable away from the logic board to disconnect it.
  10. Panasonic PV-GS9 LCD panel replacement, LCD Panel Removal: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic PV-GS9 LCD panel replacement, LCD Panel Removal: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the indicated 4.5mm screws from the LCD side of the camera.
  11. Panasonic PV-GS9 LCD panel replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic PV-GS9 LCD panel replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic PV-GS9 LCD panel replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place a plastic opening tool under the bottom of the blue panel beneath the camcorder.
    • Move the plastic opening tool up the side of the camcorder as shown. Carefully separate the LCD panel from the rest of the camcorder.
    • Remove the panel from the camcorder.
    • Using two tools can help for stability.
  12. Panasonic PV-GS9 LCD panel replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic PV-GS9 LCD panel replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic PV-GS9 LCD panel replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before removing the LCD panel from the camcorder, disconnect all the ribbon cables joining the LCD panel to the logic board.
    • There may be multiple ribbon cables attached to the same point on the logic board.
Nate Chamness
crwdns2935283:004/15/10crwdne2935283:0
24 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-9, Maness Spring 2010 crwdns2935289:0Cal Poly, Team 7-9, Maness Spring 2010crwdne2935289:0
CPSU-MANESS-S10S7G9
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 4,015
