Is your camera not turning on? A quick battery replacement may solve your problem.
            Turn the camera off and identify the battery door located on the bottom of the camera.
            Slide the "open" latch to the left: the battery door should spring open.
            To release the battery, slide the white release lever next to the SD card slot.
            The battery should now be released; you may now remove the battery from the camera body.
Repair guide is very clear and well-done
