Panasonic Lumix DMC-ZS8 Battery Compartment Cover Replacement
  1. Panasonic Lumix DMC-ZS8 Battery Compartment Cover Replacement, Battery Compartment Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom Phillips head screws on the camera to take off the outer plastic housing. Be careful when pulling the piece off; if something seems stuck, double check to make sure every screw on the bottom was removed.
  2. Panasonic Lumix DMC-ZS8 Battery Compartment Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS8 Battery Compartment Cover Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS8 Battery Compartment Cover Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the screws have been removed, slowly and carefully take the top half of the housing off the camera.
    • Flip the camera over, and carefully lift the screen while still making sure it's fully attached to the camera.
  3. Panasonic Lumix DMC-ZS8 Battery Compartment Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS8 Battery Compartment Cover Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the screen flipped over, you now have access to the metal plate under it. Using the same Phillips screwdriver, remove the metal plate. Doing this will give you access to the push pin holding the cover in place.
    • Use a small needle, pin, or needle nose pliers to slide the pin right out. Be sure to keep the pin and spring in a safe spot to prevent loss.
  4. Panasonic Lumix DMC-ZS8 Battery Compartment Cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have replaced the the pin and spring with the new cover, be sure to check that the spring action still functions. Also check that the battery sits properly in the compartment and the cover locks and fits properly.
    • If this works, then you're done! When reassembling the camera, be sure to make sure that all of the screws go tightly back in place in the same order that they were taken out.
To reassemble your device, follow these instructions in reverse order. Be sure to check that the spring action still functions and that the battery fits while still closing and locking properly.
David Garza
crwdns2935283:003/03/15crwdne2935283:0
141 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 13-13, Blackburne Spring 2015 crwdns2935289:0Sam Houston State, Team 13-13, Blackburne Spring 2015crwdne2935289:0
SHSU-BLACKBURNE-S15S13G13
Je cherche la procédure pour remplacer le couvercle du compartiment batterie sur mon Panasonic Lumix DMC GX7
Pierre Autphenne / autphennepierre61@gmail.com
Pierre Autphenne - crwdns2934203:0crwdne2934203:0
Bonjour Ou peut on acheter le cache pour la batterie ? Merci
Maud Marechal - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 2,837
