Panasonic Lumix DMC-ZS60 Camera Lens Replacement
  1. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your finger to slide the black latch from the locked position to the open position on the memory card/battery door. This will open the door of the camera.
  2. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push up the black tab on the right-hand-side to spring release the battery.
  3. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery by sliding it out from the camera.
  4. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, LCD Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement, LCD Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement, LCD Screen: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #000 Screwdriver, unscrew six 3mm screws. There are two screws located on three sides excluding the top.
  5. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off back casing and set aside.
  6. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the right side control dial circuit board up.
    • Use tweezers to pry up the white retaining flap and gently pull the circuit board out.
    I broke the white retaining clip on this step. Did not realize you need to pull up on the rear of the clip to get it to release, it is hard to tell from the picture what is going on.
    Rob Durkin - crwdns2934203:0crwdne2934203:0
  7. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the LCD screen to the left.
    • Unscrew the two 3mm on the top right side using the Phillips #000 Screwdriver.
    • Lift the gray plate cover off.
  8. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to pry up the black retaining flat and gently pull to free the LCD screen from the device.
  9. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove these three 3 mm screws with a Phillips #000 screwdriver.
  10. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect these 9 ribbon cables from the motherboard. One ribbon cable is hidden underneath the larger one on the left.
    • Use tweezers to first lift up the retaining flaps for each connector, then pull out the ribbon cable.
  11. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now you will able to lift the motherboard up and it will only be connected by two cables.
    • To fully remove the motherboard, you will have to solder the metal in order to remove the wires.
    • For more information on soldering, please visit the How to Solder and Desolder Connections guide.
  12. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Camera Lens: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Camera Lens: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the three 3mm screws attached to the plate cover using a Phillips #000 Screwdriver.
    • Pull off the plate cover to uncover the camera lens.
  13. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the camera lens from the camera.
Jade Blackert
crwdns2935283:001/16/20crwdne2935283:0
229 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S7-G10, Rauch Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S7-G10, Rauch Spring 2020crwdne2935289:0
ERAU-RAUCH-S20S7G10
A few years ago, I had a 30x zoom like this. It got a spot of dust inside the lens that showed up in photos, especially zoomed-in. I tried to unscrew the front of the lens to clean out the dust but the plastic broke, ruining the camera.
Fred Oswald - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 70
crwdns2942667:0crwdne2942667:0 2,910
