Panasonic Lumix DMC-ZS60 Camera Lens Replacement
  1. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your finger to slide the black latch from the locked position to the open position on the memory card/battery door. This will open the door of the camera.
  2. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push up the black tab on the right-hand-side to spring release the battery.
  3. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery by sliding it out from the camera.
  4. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, LCD Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement, LCD Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement, LCD Screen: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the Phillips #000 Screwdriver, unscrew six 3mm screws. There are two screws located on three sides excluding the top.
  5. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off back casing and set aside.
  6. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the right side control dial circuit board up.
    • Use tweezers to pry up the white retaining flap and gently pull the circuit board out.
  7. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the LCD screen to the left.
    • Unscrew the two 3mm on the top right side using the Phillips #000 Screwdriver.
    • Lift the gray plate cover off.
  8. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to pry up the black retaining flat and gently pull to free the LCD screen from the device.
  9. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove these three 3 mm screws with a Phillips #000 screwdriver.
  10. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect these 9 ribbon cables from the motherboard. One ribbon cable is hidden underneath the larger one on the left.
    • Use tweezers to first lift up the retaining flaps for each connector, then pull out the ribbon cable.
  11. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now you will able to lift the motherboard up and it will only be connected by two cables.
    • To fully remove the motherboard, you will have to solder the metal in order to remove the wires.
    • For more information on soldering, please visit the How to Solder and Desolder Connections guide.
  12. Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Camera Lens: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement, Camera Lens: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the three 3mm screws attached to the plate cover using a Phillips #000 Screwdriver.
    • Pull off the plate cover to uncover the camera lens.
  13. Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS60 Camera Lens Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the camera lens from the camera.
Jade Blackert
crwdns2935283:001/16/20crwdne2935283:0
237 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S7-G10, Rauch Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S7-G10, Rauch Spring 2020crwdne2935289:0
ERAU-RAUCH-S20S7G10
A few years ago, I had a 30x zoom like this. It got a spot of dust inside the lens that showed up in photos, especially zoomed-in. I tried to unscrew the front of the lens to clean out the dust but the plastic broke, ruining the camera.
Fred Oswald - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 3,180
