If your Panasonic Lumix DMC-ZS60 is experiencing battery troubles, like not turning on or holding charge, you may need to replace it. Follow this guide in order to replace your battery.
A functional battery allows the user to take pictures and enjoy their camera to the fullest without worrying about it dying unexpectedly. A battery will begin to lose its charging capacity after going through a few charging cycles. If you experience this problem, it’s time to get a new battery.
Ensure your device is powered off before attempting to remove the battery.
Use your finger to slide the black latch from the locked position to the open position on the memory card/battery door. This will open the door of the camera.
Push up the black tab on the right-hand-side to spring release the battery.
Remove the battery by sliding it out from the camera.
