Panasonic Lumix DMC-ZS6 LCD Assembly Replacement
  1. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement, LCD Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery and SD card.
  2. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two bottom 1.0 mm screws with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the left with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the right with a Phillips #000 screwdriver.
  3. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the back of the camera from the main body carefully.
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged.
  4. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of the spudger to flip up the black tabs on the ribbon cables.
    • Pull gently on the ribbon cables to unseat them.
  5. Panasonic Lumix DMC-ZS6 LCD Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the tip of the spudger to flip up the metal tabs.
    • Lift the LCD panel out of place carefully.
Derrick Thompson
crwdns2935283:001/30/18crwdne2935283:0
1,035 crwdns2915208:0crwdne2915208:0
Baylor, Team S2-G5, Johnson Spring 2018 crwdns2935289:0Baylor, Team S2-G5, Johnson Spring 2018crwdne2935289:0
BU-JOHNSON-S18S2G5
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 282
