Panasonic Lumix DMC-ZS6 Flash Assembly Replacement
  1. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement, Flash Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery and the SD card.
  2. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two 1.0 mm screws on the bottom with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the left with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the right with a Phillips #000 screwdriver.
  3. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the back of the camera from the main body carefully.
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged.
  4. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of the spudger to flip up the black tabs on the ribbon cables.
    • Pull gently on the ribbon cables to unseat them.
  5. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 1.0 mm screws to the left with Phillips #000 screwdriver.
    • Unscrew the 1.0 mm screws to the right with Phillips #000 screwdriver.
    • Unscrew the one bottom 1.0 mm screw with a Phillips #000 screwdriver.
  6. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the front of the camera from the main body carefully.
  7. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of the spudger to disengage the plastic tab.
    • Lift the selector switch away from the motherboard carefully.
  8. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the three silver 1.0 mm screws with a Phillips #000 screwdriver.
    • Use the tip of the spudger to disengage the metal tab, then carefully lift the shield away from the motherboard.
  9. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the tip of the spudger into the center hole of the tripod mount, and apply force in the direction facing away from the button.
    • Lift the tripod mount out of the camera body carefully.
  10. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to flip up the brown tab on the motherboard and carefully unseat the ribbon cable.
    • Insert the tip of the spudger into the hole on the daughterboard, then apply upward force to remove the daughterboard from the main case.
  11. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to flip up the two tabs on the motherboard and carefully unseat the ribbon cables.
    • Use the Phlllips #000 screwdriver to remove the three silver 1.0 mm screws.
    • Lift the lens assembly out of the camera carefully.
  12. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of the spudger to disengage the tab on the back of the camera.
    • Use the tip of the spudger to disengage the two tabs on the front of the camera.
    • Lift the top assembly out of place carefully.
  13. Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS6 Flash Assembly Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to disengage the two tabs.
    • Lift the flash assembly out of place carefully.
Derrick Thompson
crwdns2935283:001/30/18crwdne2935283:0
1,035 crwdns2915208:0crwdne2915208:0
Baylor, Team S2-G5, Johnson Spring 2018 crwdns2935289:0Baylor, Team S2-G5, Johnson Spring 2018crwdne2935289:0
BU-JOHNSON-S18S2G5
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 293
