Panasonic Lumix DMC-ZS3 Battery Replacement
  1. Panasonic Lumix DMC-ZS3 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the camera upside down and locate the battery compartment on the bottom panel.
  2. Panasonic Lumix DMC-ZS3 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery compartment latch to the right, then lift the door open to access the battery.
    • Using your fingernail or a spudger, slide the small gray latch on the battery compartment door from locked (left) to unlocked (right). The door will automatically spring open once unlocked.
  3. Panasonic Lumix DMC-ZS3 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently press down on the small gray release tab using your fingernail or a spudger to unlock the battery.
    • The battery will pop up slightly once released.
  4. Panasonic Lumix DMC-ZS3 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS3 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully remove the battery by pulling it straight out of the compartment.
    • The battery should slide out smoothly (avoid tilting or forcing it).
    • Insert the new battery, aligning the metal contacts. Push it in until it clicks into place, then close and lock the compartment door. Turn on the camera to confirm it powers up, and charge the new battery fully (about 18 hours) before first use.
You've successfully replaced the battery in your Panasonic Lumix DMC-ZS3! Power on the camera to verify it works, then fully charge the new battery before regular use. This quick fix can revive your device and keep it capturing memories for years to come.
Juan Pablo Quinonez Weston
crwdns2935283:004/16/13crwdne2935283:0
4 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-60, Johann Spring 2013 crwdns2935289:0Cal Poly, Team 13-60, Johann Spring 2013crwdne2935289:0
CPSU-JOHANN-S13S13G60
crwdns2942667:0crwdne2942667:0 1,489
