Panasonic Lumix DMC-ZS25 Flash Replacement
  1. Panasonic Lumix DMC-ZS25 Flash Replacement, Flash: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS25 Flash Replacement, Flash: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a small screwdriver, remove the four 3.4mm screws from the right and left sides of your Panasonic Lumix Camera.
  2. Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a small screwdriver, remove the two 2.6mm screws located next to the battery, on the outer casing.
  3. Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, open the outer cover of your device.
    • The easiest way to open your device is by placing the tool in the HDMI port.
  4. Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the spudger, pull upward on the screen cable to release it.
  5. Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, lift the button board until it clicks.
  6. Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, lift the screen until it clicks.
  7. Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a small screwdriver, remove the two 4.2mm screws located on the corner of the inner cover, under the screen.
  8. Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, remove the inner cover.
  9. Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your hands or the opening tool, separate the device into two pieces, as shown.
  10. Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the spudger, remove the black side cover.
  11. Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your hands, remove the front cover.
  12. Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the spudger, unlock the screen cables from the circuit board.
    • Lift up the black clip to release the cables.
  13. Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your hands, remove the lens.
  14. Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, pull up on the edge of the circuit board until it clicks.
    • Remove the board.
  15. Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a small screwdriver, remove the 3.7 mm screw near the green chip inside the camera, as shown. This will release the top of the camera.
  16. Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the opening tool, pull up on the edge of the top cover to unlock it.
  17. Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the opening tool, remove the top board.
  18. Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the tip of the spudger at the edge of the top board, and work around three sides to loosen it.
    • Using the opening tool, lift up the top board. Now you will be able to safely remove the flash.
  19. Panasonic Lumix DMC-ZS25 Flash Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the old flash, and put in the replacement.
Abbas Khan
crwdns2935283:001/21/15crwdne2935283:0
482 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-5, Brown Winter 2015 crwdns2935289:0USF Tampa, Team 9-5, Brown Winter 2015crwdne2935289:0
USFT-BROWN-W15S9G5
crwdns2942667:0crwdne2942667:0 545
