Panasonic Lumix DMC-ZS25 Screen Replacement
  1. Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to open the outer cover of your device from the HDMI port.
    • Open it carefully to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS25  Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS25  Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to carefully detach the ribbon cable without breaking it.
  4. Panasonic Lumix DMC-ZS25  Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to lift and remove the buttons board as shown.
  5. Panasonic Lumix DMC-ZS25  Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS25  Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the screen using the plastic opening tool as shown.
    The screen replacement I purchased does not have the black tape at the end of the ribbon cable. Will this make a difference in whether the screen will work?
    Alicia - crwdns2934203:0crwdne2934203:0
Abbas Khan
crwdns2935283:001/21/15crwdne2935283:0
482 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-5, Brown Winter 2015 crwdns2935289:0USF Tampa, Team 9-5, Brown Winter 2015crwdne2935289:0
USFT-BROWN-W15S9G5
- Of the two 2.60 mm screws on the bottom of the camera, only the one closest to the back needs to be removed.
- The correct screwdriver is JIS Type S #00. A Phillips driver can ruin the screws.
- The screen shown in step 5 consists of two parts: the LCD and a frame. The replacement LCD that I ordered came without the frame, so a little more disassembly was required, including a bit of delicate soldering: the narrow ribbon cable is really two cables, soldered together. The solder joints are hidden under the piece of black electric tape at the end.
nasorenga - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,455
