Panasonic Lumix DMC-ZS25 Power Button Replacement
  1. Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Power Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to open the outer cover of your device.
    • The easiest place to open your device is from the HDMI port.
    • Open it gently to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Power Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS25  Power Button Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to detach the ribbon cable.
    • Be careful when you use the spudger because you do not want to break the the ribbon.
  4. Panasonic Lumix DMC-ZS25  Power Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS25  Power Button Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS25  Power Button Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the button board using the plastic opening tool.
    • Remove the screen. Lift the screen from the right hand side.
    • After your hear a "click" sound, you have successfully opened the screen.
  5. Panasonic Lumix DMC-ZS25  Power Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS25  Power Button Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two black screws that are located beneath the screen.
    • Lift the metal cover using the plastic opening tool.
  6. Panasonic Lumix DMC-ZS25  Power Button Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS25  Power Button Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opener to remove the side covers.
  7. Panasonic Lumix DMC-ZS25  Power Button Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-ZS25  Power Button Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the side covers, you will be able to take away the front cover with your hands.
    • Do not apply too much pressure on the outer cover of your device to avoid damage.
  8. Panasonic Lumix DMC-ZS25  Power Button Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To release the top cover of the camera, you need to open the 3.70 mm screw shown in the picture.
  9. Panasonic Lumix DMC-ZS25  Power Button Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top cover using the plastic opening tool.
  10. Panasonic Lumix DMC-ZS25  Power Button Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS25  Power Button Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-ZS25  Power Button Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the top cover of the camera, you will be able to easily remove the power button with your hand.
Abbas Khan
crwdns2935283:001/21/15crwdne2935283:0
482 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-5, Brown Winter 2015 crwdns2935289:0USF Tampa, Team 9-5, Brown Winter 2015crwdne2935289:0
USFT-BROWN-W15S9G5
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 705
