Panasonic Lumix DMC-GX85 Display Screen Replacement
  1. Panasonic Lumix DMC-GX85 Display Screen Replacement, Display Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the camera so that the shutter side faces the ground and the lens faces you.
  2. Panasonic Lumix DMC-GX85 Display Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Display Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Display Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 2mm Phillips #0 screws on the bottom of the screen.
  3. Panasonic Lumix DMC-GX85 Display Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-GX85 Display Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Swivel the screen away from the camera body so it is facing the ground.
  4. Panasonic Lumix DMC-GX85 Display Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Display Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Display Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 6.0mm Phillips #0 screws on the back of the screen.
  5. Panasonic Lumix DMC-GX85 Display Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Display Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Display Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the camera so the lens is facing the ground.
    • Using the gap created behind the screen at the bottom, stick the iFixit opening tool inside the gap and gently open the gap.
    • Work the tool evenly around the back of the display to evenly separate the two pieces. Once the back cover is separated enough, remove it by hand.
  6. Panasonic Lumix DMC-GX85 Display Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Display Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-GX85 Display Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be sure to use extreme caution when handling the ribbon cable to ensure the wiring within it stays intact.
    • Place the camera so that the lens is facing the ground.
    • Using the iFixit opening tool, pry the black connector open and remove the ribbon.
  7. Panasonic Lumix DMC-GX85 Display Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the screen from the camera body.
    Hello, thanks a lot for this detailed tutorial.
    I am looking to buy the replacement screen but the link is dead, would somebody have any idea where to find one ?
    Thanks a lot in advance !
    Emilien Guichard - crwdns2934203:0crwdne2934203:0
Hae Bom
crwdns2935283:009/17/19crwdne2935283:0
560 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S22-G2, Branham Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S22-G2, Branham Fall 2019crwdne2935289:0
ERAU-BRANHAM-F19S22G2
Hi ! Thanks for the tutorial, any idea if this would be the same repair with a DC-GX9 ? The screen size seems to match
Clem - crwdns2934203:0crwdne2934203:0
Thanks for the guide. From step 7, how do I further dismantle the screen. I bought a replacement screen, but its in a simpler form
Kamil Zidane - crwdns2934203:0crwdne2934203:0
This is a great guide for getting the screen off of the camera, but falls short of an actual repair. More disassembly is required to repair the screen with a replacement screen bought off of eBay. How do you remove the screen from the metal frame as there seems to be even more parts that need to be separated?
John W. - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 123
crwdns2942667:0crwdne2942667:0 5,246
