Panasonic Lumix DMC-FZ1000 Motherboard Replacement
  1. Panasonic Lumix DMC-FZ1000 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-FZ1000 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-FZ1000 Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the switch on the bottom of your camera from the right (LOCK) to the left (OPEN).
    • The battery door will swing open.
  2. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull down on the lever that holds the battery.
    • The battery will pop out of its casing.
  3. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull out the battery.
  4. Panasonic Lumix DMC-FZ1000 Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-FZ1000 Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-FZ1000 Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push in on the SD card inside the battery housing.
    • The SD card will pop out.
    • Pull out the SD card.
    • Close the battery housing door.
    Il faut modifier “Étape 4 Carte mère” par “Étape 4 Carte mémoire”, mais je n’y arrive pas.
    Jojo Demonnom - crwdns2934203:0crwdne2934203:0
  5. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 5.2 mm Phillips #00 screws that are 1) below the label and 2) above the tripod mount hole on the bottom of the camera.
    • You may ignore the screw below the tripod mount hole.
    • Remove the two 5.5 mm Phillips #00 screws on the side of the camera with the MIC jack.
    • Remove the two 7.0 mm Phillips #00 screws that are 1) above and 2) below the HDMI panel.
    • You may ignore the screw that goes through the leather material to the right of the HDMI panel.
    Quitar también los Phillips #?? zona de abajo del visor, desmontar ,y , quitar otros 2 phillips #?? interiores.
    blufs - crwdns2934203:0crwdne2934203:0
    • There are two screws that hold the eye piece on to the main housing, just underneath. Remove these. Once these have been removed, gently pull and remove the eye piece and remove the now accessible top two screws.
  6. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Do not yank off the back plate. If you do, you will tear the electronic ribbons attached to the inside of the camera and the back plate.
    • Gently lift up the back plate, being careful not to damage any ribbons.
    • Do not yank out the electronic ribbons attached to the motherboard and the back plate, or you may damage them. To properly detach these ZIF connector ribbons, see this technique on disconnecting ZIF connectors.
    • Pull to disconnect from the motherboard the two ZIF connector ribbons attached to the back plate.
    • Set aside the back plate.
    The eyepiece needs to be removed!
    Remove the phillips screws from the bottom of the eyepiece, remove the eyepiece and remove the two screws at the top of the eyepiece
    bailout00 - crwdns2934203:0crwdne2934203:0
  7. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Do not yank out the electronic ribbons attached to the motherboard, or you may damage them. To properly detach these ZIF connector ribbons, see this technique on disconnecting ZIF connectors.
    • Pull to disconnect from the motherboard the seven ZIF connector ribbons.
    Die Anleitung zum Öffnen von ZIF-Anschlüssen hilft leider nicht weiter. Die Plastikbügel zerbrechen beim Versuch sie nach Anleitung aufzuklappen. Diesen wesentlichen Arbeitsschritt mit Bildern zu versehen wäre vielleicht hilfreich gewesen...
    Jan - crwdns2934203:0crwdne2934203:0
  8. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 5.2 mm Phillips #00 screws at the corners of the motherboard.
  9. Panasonic Lumix DMC-FZ1000 Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-FZ1000 Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly grasp the left side of the motherboard.
    • Pull out the motherboard.
    • If you find it difficult to remove the motherboard, pull it away from the HDMI panel while pulling it out.
    FZ1000 MK2: I could not remove the motherboard by itself but it came off easily together with the metal plate.
    Francesco Nardone - crwdns2934203:0crwdne2934203:0
crwdns2935229:08crwdne2935229:0
Robseth Taas
crwdns2935283:001/07/16crwdne2935283:0
1,793 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 70-5, Forte Winter 2016 crwdns2935289:0Cal Poly, Team 70-5, Forte Winter 2016crwdne2935289:0
CPSU-FORTE-W16S70G5
Where do you buy a motherboard for this camera?
Pekka Liemola - crwdns2934203:0crwdne2934203:0
This article is useless, since the motherboards are not available anywhere.
Pete Schliebner - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 7,915
