Remplacement de l'écran LCD du Panasonic Lumix DMC-FX07 LCD
  1. Remplacement de l'écran LCD du Panasonic Lumix DMC-FX07 LCD, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Move the switch on the battery door to the Open position.
    • The door will automatically swing open after you let it go.
  2. Remplacement de l'écran LCD du Panasonic Lumix DMC-FX07 LCD: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remplacement de l'écran LCD du Panasonic Lumix DMC-FX07 LCD: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
    • Keep your finger clear of the battery when it pops out.
  3. Remplacement de l'écran LCD du Panasonic Lumix DMC-FX07 LCD, Memory Card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the memory card in and let go.
    • The memory card will pop out slightly.
    • Pull out the memory card.
  4. Remplacement de l'écran LCD du Panasonic Lumix DMC-FX07 LCD, Back Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remplacement de l'écran LCD du Panasonic Lumix DMC-FX07 LCD, Back Cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the small screws on the sides of the camera.
    • The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
  5. Remplacement de l'écran LCD du Panasonic Lumix DMC-FX07 LCD: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Remplacement de l'écran LCD du Panasonic Lumix DMC-FX07 LCD: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the three small screws on the bottom(#00P, 3.3mm).
    • The bottom will fall off.
  6. Remplacement de l'écran LCD du Panasonic Lumix DMC-FX07 LCD: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remplacement de l'écran LCD du Panasonic Lumix DMC-FX07 LCD: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remplacement de l'écran LCD du Panasonic Lumix DMC-FX07 LCD: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up the bottom back cover by prying the bottom edge with the spudger.
    • Gently lift up the back cover with your hand from the bottom to the top.
  7. Remplacement de l'écran LCD du Panasonic Lumix DMC-FX07 LCD: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remplacement de l'écran LCD du Panasonic Lumix DMC-FX07 LCD: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remplacement de l'écran LCD du Panasonic Lumix DMC-FX07 LCD: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the tabs on the ZIF connectors.
    • The ribbon cables should easily come out of the ZIF connectors.
  8. Remplacement de l'écran LCD du Panasonic Lumix DMC-FX07 LCD, Afficheur LCD: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Remplacement de l'écran LCD du Panasonic Lumix DMC-FX07 LCD, Afficheur LCD: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Remplacement de l'écran LCD du Panasonic Lumix DMC-FX07 LCD, Afficheur LCD: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of the spudger to pry off the LCD screen from the back cover. Place the tip of the spudger in the small hole in the bracket on the LCD screen and lift it out.
Pour remonter votre appareil, suivre les instructions dans l'ordre inverse.
James Cruz
crwdns2935283:004/14/12crwdne2935283:0
6 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-23, Amido Spring 2012 crwdns2935289:0Cal Poly, Team 6-23, Amido Spring 2012crwdne2935289:0
CPSU-AMIDO-S12S6G23
crwdns2942667:0crwdne2942667:0 2,018
