Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement
  1. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Move the switch on the battery door to the Open position.
    • The door will automatically swing open after you let it go.
  2. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
    • Keep your finger clear of the battery when it pops out.
  3. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Memory Card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the memory card in and let go.
    • The memory card will pop out slightly.
    • Pull out the memory card.
  4. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the small screws on the sides of the camera.
    • The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
  5. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the three small screws on the bottom(#00P, 3.3mm).
    • The bottom will fall off.
  6. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up the bottom back cover by prying the bottom edge with the spudger.
    • Gently lift up the back cover with your hand from the bottom to the top.
  7. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the tabs on the ZIF connectors.
    • The ribbon cables should easily come out of the ZIF connectors.
  8. Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Panel Buttons: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic Lumix DMC-FX07 Back Panel Buttons Replacement, Back Panel Buttons: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently wiggle out the top motherboard.
    • The buttons are hardwired into this logic board.
Karissa
crwdns2935283:004/13/12crwdne2935283:0
50 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-23, Amido Spring 2012 crwdns2935289:0Cal Poly, Team 6-23, Amido Spring 2012crwdne2935289:0
CPSU-AMIDO-S12S6G23
crwdns2942667:0crwdne2942667:0 1,012
