Is your camera still not turning on even with a working battery? Are your pictures not storing properly? Is your screen working, but still not displaying pictures? These problems may be due to a broken or faulty motherboard.
Looking at the bottom of the camera, slide the OPEN/LOCK switch to the left into the OPEN position.
Flip the inside switch up to release the battery.
Grip the edge of the battery and pull it out.
Use a Phillips #000 screwdriver to remove the five 4.5 mm screws located on the bottom of the camera and the top one on the left side, with the lens facing you.
Use a Phillips #000 screwdriver to remove the two 3.5 mm screws, one below the lens and one on the left side.
Use a Phillips #000 screwdriver to remove the 7.1 mm screw from the right side of the camera.
Use a Phillips #000 screwdriver to remove the 2.5 mm screw underneath the viewfinder.
Pull the black plastic piece off of the viewfinder.
Slide out the black plastic piece that acts as a placeholder for an attachable lens on the top of the camera.
Remove the small metal insert that rests beneath the black plastic piece by pulling outward, away from the lens side of the camera.
Use a Phillips #000 screwdriver to remove all four of the 7.1mm screws that are under the metal piece.
Pry off the back of the camera using a spudger starting from the top right side of the LCD screen.
Use a Phillips #000 screwdriver to remove the 7.5mm screw on the top right of the back of the camera that holds the metal backing in place.
Lift the LCD screen away from the device.
Pry off the silver metal backing with a spudger.
Pull out the ribbon cable that attaches the LCD screen to the motherboard.
Remove the LCD screen.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Disconnect the nine visible ribbon cables/ZIF connectors by flipping the black bars up and pulling the ribbon straight out of the connector.
Disconnect two more cables in the upper left corner of the board, hidden behind the visible cables.
Use a Phillips #000 screwdriver to remove the two 4.5 mm screws.
Use a Phillips #000 screwdriver to remove the 2.5 mm screw.
Use two fingers to gently pull the viewfinder toward you and out of its housing.
Start at the top of the camera and use the plastic spudger to pry the motherboard out of the camera.
This camera is a true dust harvester.
Thanks to this guide I have dared to clean the sensor successfully.
I know that I will have to return to the task in a few months but now I am more sure of the process.
Thanks a lot
Just a quick question! After replacing the motherboard, the camera works just fine or is it needed a software intervention?
