Panasonic HDC-TM90 LCD Screen Replacement
  1. Panasonic HDC-TM90 LCD Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the LCD screen.
  2. Panasonic HDC-TM90 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery release switch away from the battery.
  3. Panasonic HDC-TM90 LCD Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While holding the switch away from the battery, push the battery out of the slot.
  4. Panasonic HDC-TM90 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the camera.
  5. Panasonic HDC-TM90 LCD Screen Replacement, Lens: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Panasonic HDC-TM90 LCD Screen Replacement, Lens: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Panasonic HDC-TM90 LCD Screen Replacement, Lens: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 5 screws from the side panel body of the camcorder.
    • Use the spudger to remove the top of the camcorder.
  6. Panasonic HDC-TM90 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic HDC-TM90 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew three screws to remove the lens rim on the front of the camcorder.
    • Be aware of the wires attaching the lens rim to the body of the camcorder. You will not be able to separate the lens rim completely.
    • Use caution when separating the shutter lever.
  7. Panasonic HDC-TM90 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber ring around the lens.
  8. Panasonic HDC-TM90 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the lens by removing the three screws connected to it.
  9. Panasonic HDC-TM90 LCD Screen Replacement, LCD Screen: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic HDC-TM90 LCD Screen Replacement, LCD Screen: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the side panel of the camcorder.
    • Remove the top panel of the camcorder.
    • For help with this step see prerequisite guide: Lens Clean.
  10. Panasonic HDC-TM90 LCD Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open camcorder screen.
  11. Panasonic HDC-TM90 LCD Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the LCD screen perpendicular to the camcorder.
    • Remove the screws.
    • Have caution when you remove the screen. There is a wire connecting it to the rest of the camera that should not be detached.
  12. Panasonic HDC-TM90 LCD Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry the plastic backing on the screen using a metal spudger.
  13. Panasonic HDC-TM90 LCD Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic HDC-TM90 LCD Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back the black tape holding the wire strip to the camcorder screen.
    • Unclip the small latch from the wire strip.
  14. Panasonic HDC-TM90 LCD Screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws from the metal frame.
    • Be careful when holding the screen after the frame has been unscrewed. The screen and all of its components are unattached and can fall apart.
BayleeVersteeg
crwdns2935283:001/30/17crwdne2935283:0
37 crwdns2915208:0crwdne2915208:0
Baylor, Team 8-4, Whitney Spring 2017 crwdns2935289:0Baylor, Team 8-4, Whitney Spring 2017crwdne2935289:0
BU-WHITNEY-S17S8G4
Steps 1-4 are good pre-reqs.
Are all of steps 5-8 absolutely necessary for LCD screen replacement?
Step 9-bullet 3: Change to 'note' rather than bullet point and put it first.
Step 11-bullet 2: List the # of screws to be removed and with what screwdriver. Show 2nd picture of screws to remove on actual LCD door.
Step 11-bullet 3: Change to a "caution" rather than just a bullet. Also we had a spring fall out at this step with no idea where it came from. Perhaps you could address this.
Step 12- We actually had to use a 2nd spudger to pry it apart. One as a wedge and one as a lever to separate.
Step 14-bullet 2: change to a "Warning" symbol.
Seems to be an incomplete guide, as the LCD screen is still affixed to the device.
Rene Klopf - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 657
