Panasonic ES2207P Motor Replacement
  1. Panasonic ES2207P Motor Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove foil head and blades.
  2. Panasonic ES2207P Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove (2) 7.9mm Phillips #0 screws.
    • Remove (2) 14.3mm Phillips #0 screws.
  3. Panasonic ES2207P Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the blade mount assembly towards the rear of razor and remove.
  4. Panasonic ES2207P Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be careful not to break any tabs that hold the panels to the body.
    • Remove both external panels using spudger if necessary.
  5. Panasonic ES2207P Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  6. Panasonic ES2207P Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This step may require a fair amount of force due to the O-ring.
    • Pull to separate the end-cap from the body.
  7. Panasonic ES2207P Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove (2) 7.9mm Phillips #0 screws and remove endcap from frame.
  8. Panasonic ES2207P Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic ES2207P Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push forward on the lower terminal to remove the battery from the frame.
  9. Panasonic ES2207P Motor Replacement, Motor: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic ES2207P Motor Replacement, Motor: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove battery contact.
  10. Panasonic ES2207P Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using pointed end of spudger, push on the motor through the hole in the back
  11. Panasonic ES2207P Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers to finish removing motor from frame.
Kevin Marvell
crwdns2935283:011/06/17crwdne2935283:0
309 crwdns2915208:0crwdne2915208:0
IUPUI, Team S6-G5, Baechle Fall 2017 crwdns2935289:0IUPUI, Team S6-G5, Baechle Fall 2017crwdne2935289:0
IUPUI-BAECHLE-F17S6G5
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 482
