Over time batteries can lose their ability to maintain a charge. This guide demonstrates how to replace the battery.
Remove (2) 7.9mm Phillips #0 screws.
Remove (2) 14.3mm Phillips #0 screws.
Push the blade mount assembly towards the rear of razor and remove.
Remove both external panels using spudger if necessary.
Pull to separate the end-cap from the body.
Remove (2) 7.9mm Phillips #0 screws and remove endcap from frame.
Push forward on the lower terminal to remove the battery from the frame.
Where to buy the battery? Can you provide more details?
Onde comprar bateria?
super great job on the break down. Thanks
