Panasonic ER-GN30-K Motor Shaft Replacement
  1. Panasonic ER-GN30-K Motor Shaft Replacement, Motor Shaft: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Motor Shaft Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
  3. Panasonic ER-GN30-K Motor Shaft Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  4. Panasonic ER-GN30-K Motor Shaft Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The motor shaft should be sticking out from the top of the device.
    • Use the metal prying tool to pry apart the silver plastic case .
    • Pull each side of the plastic case off.
    This photo almost made me break my trimmer. You don’t stick your pry tool here but underneath the bottom.
    [deleted] - crwdns2934203:0crwdne2934203:0
  5. Panasonic ER-GN30-K Motor Shaft Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew one 20mm Phillips #00 screw.
  6. Panasonic ER-GN30-K Motor Shaft Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
  7. Panasonic ER-GN30-K Motor Shaft Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic ER-GN30-K Motor Shaft Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
    Hi, when trying to reassemble the trimmer I have a problem with the switch. I do not understand how the mechanical connection between the final switch and the inner one is done. I am wondering if I lost a part…
    Chris - crwdns2934203:0crwdne2934203:0
Alejandro Garabatos
crwdns2935283:009/03/15crwdne2935283:0
330 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 15-3, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 15-3, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S15G3
Thank you, small parts where switch is could be shown as well. Would be very helpful.
Advise for putting things back together: remove plastic switch cover and put back only after full reassembly
Aurimas Miko - crwdns2934203:0crwdne2934203:0
Dear Alejandro,
thank You for your instruction, my question is where this motor shaft part is available? I can’t find it anywhere on the net. Thanks if you can help. Bence Fazekas
fazebence - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2942667:0crwdne2942667:0 1,725
