Panasonic ER-GN30-K Motor Replacement
  1. Panasonic ER-GN30-K Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
  3. Panasonic ER-GN30-K Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  4. Panasonic ER-GN30-K Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a metal spudger to pry apart the silver plastic case.
    • Pull each side of the plastic case off.
  5. Panasonic ER-GN30-K Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew one 20mm Phillips #00 screw.
  6. Panasonic ER-GN30-K Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
  7. Panasonic ER-GN30-K Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic ER-GN30-K Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
  8. Panasonic ER-GN30-K Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motor from the case by sliding the cover off of it.
    you are really awesome . How can I make it run on electricity
    Medo Medo - crwdns2934203:0crwdne2934203:0
Corey Tappan
crwdns2935283:008/27/15crwdne2935283:0
209 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 15-3, Blackwell Fall 2015 crwdns2935289:0USF Tampa, Team 15-3, Blackwell Fall 2015crwdne2935289:0
USFT-BLACKWELL-F15S15G3
My motor working intermittently. Took apart per instruction (very detailed, thank you). Everything loos good on the internals. I think my problem is succumb build up on the negative spring where it makes contact on negative end of battery. I scrapped it a little with tip of knife, working some what better. Need to find small wire brush to get in there and give it a good cleaning. Thank you for your guide :)
Rocko the fixit cat - crwdns2934203:0crwdne2934203:0
Thanks for such a detailed step by step to disassemble. It appears that the motor is not functioning: LD-050FF-2043V motor. But I was not able to find a replacement on the internet. Any suggestions?
David Freedman - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 4,070
