crwdns2959928:0crwdne2959928:0 ↓Use this guide to remove the right function board from the front panel of the DVD player.
Eject the disk tray from the DVD player before removing power supply.
Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
Remove the three screws running along the back edge of case cover.
Remove the two screws from each side of the case cover.
Grab edges of the cover with your hands. Pull outward slightly, then straight up.
Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
Remove 4 screws as shown.
Push in plastic retainer tab on board.
Grasp edges of board and pull out.
