This guide will show you how to replace the door covering the battery compartment. Overall this guide does not take much knowledge regarding disassembly, however you should take care to remember how the parts are situated before removing them.
Set the switch on the battery door to "open," and open the door.
At the left hand side, locate the head of the metal bar that holds the spring in place.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Push the metal bar down using the metal tweezers.
Pull the metal bar that holds the spring in place out.
Remove the battery access door from the device.
