Panasonic ARC ES-LT3N Back Casing Replacement
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Panasonic ARC ES-LT3N Back Casing Replacement, Back Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic ARC ES-LT3N Back Casing Replacement, Back Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the razor over so the back is facing you.
  2. Panasonic ARC ES-LT3N Back Casing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic ARC ES-LT3N Back Casing Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the 6 mm screw just above the charger port.
  3. Panasonic ARC ES-LT3N Back Casing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic ARC ES-LT3N Back Casing Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the plastic cover at the bottom of the razor downward to remove.
  4. Panasonic ARC ES-LT3N Back Casing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Panasonic ARC ES-LT3N Back Casing Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the rear casing from the bottom of the razor.
    • This may require you to gently pry it apart with you fingers.
    • Lift up the rear casing from the sides of the razor.
    • Pull rear casing up and off razor.
    • Be careful not to break any plastic!
Andrew Trainor
crwdns2935283:003/05/17crwdne2935283:0
648 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S8-G3, Catania Spring 2017 crwdns2935289:0UMass Dartmouth, Team S8-G3, Catania Spring 2017crwdne2935289:0
UMASSD-CATANIA-S17S8G3
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 55
