Palm m105 Display Screen Replacement
  1. Palm m105 Display Screen Replacement, Display Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the protective cover open and pull it straight away from the device to release the two clips.
  2. Palm m105 Display Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the faceplate, locate the tab at the top of the device.
    • Lift the tab upwards with your finger.
    • The tab releases easily. Excessive force is not required.
  3. Palm m105 Display Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm m105 Display Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    T5 Torx Screwdriver
    $5.49
    • Using a T5 Torx screwdriver, remove the four screws located on the back of the device.
    • With the screws removed, the device is separated into two parts (the empty back cover and the back case holding the main components).
  4. Palm m105 Display Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be careful with this step. The motherboard and screen are attached by fragile cables.
    • Slowly lift the motherboard and the screen from the back case.
    • Gently hold the screen back so that you see the cables between it and the motherboard.
  5. Palm m105 Display Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm m105 Display Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the screen from the motherboard by carefully pulling up on the three tabs.
    • Be careful. These tabs are fragile.
    • The motherboard and screen separate once the three tabs are released.
    • Recycle the old screen.
Erik Thompson
crwdns2935283:010/04/11crwdne2935283:0
31 crwdns2915208:0crwdne2915208:0
UW Stout, Team 1-3, Zhou Fall 2011 crwdns2935289:0UW Stout, Team 1-3, Zhou Fall 2011crwdne2935289:0
UWSTOUT-ZHOU-F11S1G3
crwdns2942667:0crwdne2942667:0 860
