If battery is faulty or needs replacement, follow these simple steps to replace.
To begin, gently pull on the flap to remove.
Use T6 bit of screwdriver provided in the iFixit toolkit. Unscrew the two screws at the top of the device.
Carefully remove the back panel of the device.
Gently remove the battery from the phone.
Insert new battery where old battery was.
To reassemble your device, follow these steps in reverse order
Why is nothing said about soldering of battery terminals, which I read elsewhere as a requirement?
