crwdns2935201:0crwdne2935201:0 crwdns2935203:0crwdne2935203:0
Flip the device so it's facing screen-side down.
Slide the device body upward, exposing the camera.
Use a Torx T5 screwdriver to remove the top two screws.
Remove the back sticker, or cut holes into it at the positions marked in the photo.
Remove the three bottom Phillips #00 screws.
Flip the device over so it's facing screen-side up.
Slide the screen upward by a few millimeters without detaching the screen - just enough to expose the top edge of the metallic panel so that you can reach underneath.
Use the plastic opening tool to pry off the front panel.
Remove the bottom two Phillips #00 screws.
Lift the bracket up from the device.
Remove the plastic camera button.
Bend the back plate very slightly to aid in popping it out from its home.
Use the plastic opening tool to pry off the speaker (taking care not to press on the speaker cone).
Gently lift the ribbon cable off of the lower panel. If necessary, work the opening tool (or picks) underneath the cable to loosen it from the small tabs on the lower panel, and any glue that may be hiding underneath.
Slide the back cover off.
Remove the Philips #00 screw
Remove the sliver metal piece
Remove the Philips screws #00
Remove the rear blue panel by prying both sides using the plastic opening tool.
Pull the tab up to remove the metal cap, which shields the battery.
Carefully lift the cap off the battery and logic board, being mindful of glue.
Remove the cable by pinching the sides and pulling up. You can also use the opening tool to work it loose on each side.
Pry off the battery with the plastic opening tool.
Remove Philips screw #00
Remove black plastic top part
Pull off the orange cable
Now the screen and the motherboard can be separated
Finished
