Palm Zire 71 Back Cover Replacement
  1. Palm Zire 71 Back Cover Replacement, Preparation: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device so it's facing screen-side down.
    • Slide the device body upward, exposing the camera.
  2. Palm Zire 71 Back Cover Replacement, Top Screws (2) Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Torx T5 screwdriver to remove the top two screws.
    • Don't be tempted into thinking that you can take a shortcut by prying the blue body open after these screws - there are other screws underneath the metallic back section that you can't reach yet.
  3. Palm Zire 71 Back Cover Replacement, Bottom Screws (3) Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back sticker, or cut holes into it at the positions marked in the photo.
    • Remove the three bottom Phillips #00 screws.
  4. Palm Zire 71 Back Cover Replacement, Front Panel Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Zire 71 Back Cover Replacement, Front Panel Removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device over so it's facing screen-side up.
    • Slide the screen upward by a few millimeters without detaching the screen - just enough to expose the top edge of the metallic panel so that you can reach underneath.
    • Avoid pulling up too far - there's a fragile ribbon cable underneath the panel!
    • Use the plastic opening tool to pry off the front panel.
    • This part is tricky, especially if you want to avoid damaging the panel. Opening picks are quite handy here; try inserting them in the seam at the bottom of the device, and working them around. You may also find it helpful to squeeze the sides of the device to release the sides of the front panel.
  5. Palm Zire 71 Back Cover Replacement, Bracket and Speaker Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Zire 71 Back Cover Replacement, Bracket and Speaker Removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the bottom two Phillips #00 screws.
    • Lift the bracket up from the device.
    • Remove the plastic camera button.
    • Bend the back plate very slightly to aid in popping it out from its home.
    • Use the plastic opening tool to pry off the speaker (taking care not to press on the speaker cone).
  6. Palm Zire 71 Back Cover Replacement, Back Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Palm Zire 71 Back Cover Replacement, Back Cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the ribbon cable off of the lower panel. If necessary, work the opening tool (or picks) underneath the cable to loosen it from the small tabs on the lower panel, and any glue that may be hiding underneath.
    • Avoid separating the ribbon cable from the interior of the device, and avoid separating the supportive material from the rest of the ribbon cable itself.
    • Slide the back cover off.
Jinxian Jiang
crwdns2935283:004/28/11crwdne2935283:0
323 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 1-5, Nelson Spring 2011 crwdns2935289:0CSU Los Angeles, Team 1-5, Nelson Spring 2011crwdne2935289:0
CSULA-NELSON-S11S1G5
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 2,594
