If your Zire 71 has a damaged back cover, replacing it can help spruce up the appearance of your handheld.
Flip the device so it's facing screen-side down.
Slide the device body upward, exposing the camera.
Use a Torx T5 screwdriver to remove the top two screws.
Remove the back sticker, or cut holes into it at the positions marked in the photo.
Remove the three bottom Phillips #00 screws.
Flip the device over so it's facing screen-side up.
Slide the screen upward by a few millimeters without detaching the screen - just enough to expose the top edge of the metallic panel so that you can reach underneath.
Use the plastic opening tool to pry off the front panel.
Remove the bottom two Phillips #00 screws.
Lift the bracket up from the device.
Remove the plastic camera button.
Bend the back plate very slightly to aid in popping it out from its home.
Use the plastic opening tool to pry off the speaker (taking care not to press on the speaker cone).
Gently lift the ribbon cable off of the lower panel. If necessary, work the opening tool (or picks) underneath the cable to loosen it from the small tabs on the lower panel, and any glue that may be hiding underneath.
Slide the back cover off.
