Open the 4 screws on the back
With a spudger open the case on the side
Remove the Battery with a plastic spudger
Insert the Connector straight downward
Put the battery in the same place, if necessary add glue to it
Close the case and tiden it with the screws
Completely load the battery and push the reset button.
Adjust date and time
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
